Why does some hatch not display and others do? Every time I go to plot I have to insure that the layers are loaded... Is there a setting per layer for hatch display?
Joined
Tue Feb 15, 2005 3:19 pm
Location
Lawrenceville, Georgia
not per layer. You might check Program Preferences/Misc. Tab and make sure "All" is checked for Hatch.
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.02.15 (SE)
http://www .
R ogerD onaldsonA rchitect.com
Joined
Sat Feb 12, 2005 12:33 pm
Thanks for the suggestion... Hatching was in fact selected, so still no solution. One item I forgot to mention - this occurs with XREFs only.
Joined
Location
Are the XRef's clipped? If so, is Ignore Z toggled on for the X-Clip? If this fixes it, then you can change Z-height / Base in the XRef'd file to 0.
Joined
Fri Feb 11, 2005 11:24 pm
Location
Maynard, MA, Eaarth
HandCrafted With and By SiteSplat ©SiteSplat 2013
