They should all open up just fine. You will have to use the File Type drop down when opening Datacad v5-10 files to set it to DC5 extension, but that's not changed since v14.
On thing to know is that the Go To View types have changed. I Believe this was changed in Release 13. If you use the short cut "V" to get your Go To Views, nothing will show in releases prior to the change. You need to press CTRL + F12 to get the old views. From there you can convert them to the new 3D Views.
Arthur Wood
CADD Manager
EH Danson Associates
St. Johnbury, Vermont
CADD Manager
Users browsing this forum: Google [Bot] and 20 guests
