Is it possible to add custom angles to Orthomode? say... 30 and 60 in addition to the standard 45?
Thanks!
Thanks!
Lars wrote:ok. I suppose that may have its uses.You probably still have Tangent mode turned on. Tangent mode has it's own settings for it's snap angles. Hit B to go to the Tangents menu, then check what F2 Tan Divs is set to. You can set it to 24 as well. Once you are done working in Tangent mode, you should click the F3 Cancel button in the Tangent's mode to go back to normal mode to avoid confusion. If you were to instead hit B and clicking something else trying to go back to a "normal" alignment, depending on how the object was created, it could set your X/Y axis or angles off by 90° or 180°.
Is there a reason why my Ortho angle snap would not accept a larger number of even divisions than 4? If I input 24 and hit enter... I'm still set to only 4 divisions when I try to draw. Going back into Snap Angle under Grids, it looks like 24 was accepted by DC, but its not allowing it for some reason. Any ideas what could be wrong?
Thanks!
Users browsing this forum: Mark Bell and 38 guests
