Like Custom Scales #76491 by bhcordova Tue Jun 11, 2019 11:10 am Is it possible to print using a scale other than the ones listed in the Print-Scale-menu? Do not interfere in the affairs of dragonsFor you are crunchy and taste good with ketchup Username bhcordova Posts 4 Joined Thu Sep 13, 2012 1:29 pm Location Nacogdoches, Texas Contact YIM
Like Re: Custom Scales #76493 by joshhuggins Tue Jun 11, 2019 12:16 pm Yes, see page 200 of the Manual under Editing Scale Lists. It is best to set your scale file first in your base files to your most used scales as several core functions in the program are dependent on the positions of the scales in the list. Thanks! - Josh Do. Or do not. There is no try.- Josh's Digital Downloads - Goodies for Datacad! Username joshhuggins Posts 7695 Joined Fri Feb 11, 2005 5:44 pm Location Absolute Zero, California Contact
