Can't remember what the file type used to be for our fonts. They're all .shx files now and I'm trying to use the Blocker/Report function. It's looking for ORIG2 in the old format; doesn't see ORIG2.shx.
--just wandering-
Joined
Tue Feb 15, 2005 9:56 am
used to be .chr files if I recall correctly.
Roger Donaldson AIA CSI CDT NCARB abUsing Datacad since 1986, ver 23.00.02.15 (SE)
http://www .
R ogerD onaldsonA rchitect.com
Joined
Sat Feb 12, 2005 12:33 pm
Roger D wrote: used to be .chr files if I recall correctly.This is correct.
David A. Giesselman
Senior Vice President & CTO
DATACAD LLC
dave@datacad.com Providing thoughtfully crafted, software bugs to the DataCAD community since 1984.
Rank
Chief DataCAD Troglodyte
Joined
Thu Feb 10, 2005 4:30 pm
Location
DATACAD LLC Programming Valhalla
Hopefully, this is the one that you need. I renamed it with a doc extension so that it could be attached. Woody
(1.91 KiB) Downloaded 457 times
Joined
Fri Apr 08, 2005 9:40 am
Got it; thanks. The file must be "ORIG2.chr" and then the Blocker/report works.
--just wandering-
Joined
HandCrafted With and By SiteSplat ©SiteSplat 2013
