I'm having an issue with Line To Poly. When I convert a set of lines, the result skips control points and even creates its own. Can I change the sensitivity of Line To Poly so it accepts each line/curve endpoint as part of the polyline? Starting Line To Poly from different line segments produces a different result, however, it always leaves out 3 control points. Is there a limit that I can raise?
After
Before
