Mark Bell wrote:Hi Jim, Giuseppe ,
As mentioned earlier, it's not always possible for each user to mimic exactly the full file paths on my system.
May be on the wrong track here but could you create a folder on any of your local drives c:, d:, or?, let's call the folder shared. Then share the folder as shared or work or what ever, next map the folder as let's say s:. I usually do this from a cmd prompt run as administrator -
net use s: computername\sharename
Have found I sometimes need to restart win 10 as the mapped drive doesn't always show up straight away.
In file explorer find s: drive and create a new folder for Dropbox. I would install datacad to s: apps\datacad. Setup Dropbox to sync s:\dropbox.
This could be done on each machine within the group and then your paths would match.
Would that work? It is getting late here and I probably need some sleep.
"Life isn't about dawdling to the grave, arriving safely in an attractive, wrinkle free body, but rather an adventure that ends skidding in sideways, champagne in one hand, strawberries in the other, totally worn out, screaming 'yeehaaa, what a ride!"
