We have found over the years that autosave is of limited value when the program crashes...it seems to be a lot more effective to go into temp files and save out the swap file from the affected file even with autosave set on a relatively close interval (we typically use 15minutes) we still often loose an hour plus of work. Of course the best thing is to do a forced save but it would be great if the file shelled out autosaves in much the same way it does sessions ...without constant user input. Am I alone in this desire? Or is there a macro that does this that I am unaware of?
TIm
TIm
