#79133 by DBrennfoerder
Wed Dec 02, 2020 10:54 am
V22.00.01.00 PE
Roofit does not work. The contents of the Macros folder in v21 and v22 are identical, but Roofit brings up this list: GoTo Views, Layers, Templates, Hatching, Geometry, Measures, Dimensions
No Roofit
I closed the file and reopened in v21. Same issue. No Roofit.
#79185 by Mark F. Madura
Wed Dec 09, 2020 4:38 pm
DBrennfoerder wrote:Are the guru's working on this?
Hi Dwight,
The first time RoofIt is run, the message file is loaded into the macro. This allows the message file to be translated. For some reason, this process is failing for some people. Send a message to help@datacad.com and Clay will send you a replacement macro with the message file already loaded.
MFM
