I'm having an issue with knockouts. I am using them to mask out leader lines that cut through building assemblies in sections and details. I've had them on the same layer as the leader then just push the leader to the front with no problems when printing. Now, I'm doing it the same way, yet the knockout will always mask out whatever is within the knockout boundary when printing. It looks fine when drawing and viewing linework. I've tried moving the knockouts to a different layer and putting them below the leaders with no effect. I've even restarted DC with no change. Knockouts are now blocking everything within their borders. (above and below)
My knockouts are created using closed polylines.
Color = white.
Pen weight = 1
Line Type = Solid (no borders)
Base = 0
Height = 0
I use Pen Sort when printing (although its doing the same thing using WSYWIG)
Could adjusting z-heights work?
Appearance should be as follows: Leaders above knockouts above linework.
Thanks!
Color = white.
Pen weight = 1
Base = 0
Height = 0
Thanks!
